Fluctuating Fuel Pressure questions
Old Feb 4, 2010 | 07:24 PM
Cander's Avatar
Cander
Default Fluctuating Fuel Pressure questions
What is the fuel pressure on a 1996 dodge 3500 dully v10 gas motor?
Mine is at 37 pounds after I turn the motor off.
Should the fuel pressure fluctuate when the motor is running?
Mine fluctuates between 10 and 15 pounds going from around 30 pounds to 45 pounds.
When I rev the motor up the fluctuation goes away and holds at about 37 pounds then when I let it go back to idle, the fluctuation starts again. Does this sound right?
