Where's the fuse for the cab/dome lights?
Old Feb 11, 2010 | 12:35 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Originally Posted by audioman10
its got a fuse on it i just want my light in the cab to work agin..
Except you have it connected in the fuse box that most likely only has a 16g wire supplying it. So whats the point in running 8g!
Old Feb 11, 2010 | 03:47 PM
audioman10's Avatar
audioman10
but i do not have it ran to the fuse box its got its own on off switch becouse i have it bypased to be able to play a dvd when driving down the road
Old Feb 11, 2010 | 04:25 PM
zman17's Avatar
zman17
I must have mis read your previous post saying you had it connected to the fuse in question.
Old Feb 11, 2010 | 05:03 PM
jasonw's Avatar
jasonw
Site Moderator
He has to have it connected to the normal radio fuse AND to the battery with an inline fuse.
The inline fuse/8g wire will supply the real current that he needs, but the HU has to know when to turn on, otherwise it'd stay on all the time and drain the battery. Thats what the wire to the radio fuse does, is tell it when its aloud to turn on. So if either fuse is blown (inline or radio fuse in side panel), the HU won't function. I wonder if he has an inline fuse, though, as he hasn't mentioned it.
Let me run out to the truck, I'll tell you which fuse is for radio. Gimme a few minutes.
Old Feb 11, 2010 | 05:23 PM
audioman10's Avatar
audioman10
iv got it set up to where i have an on off switch and today after i got out of school i changed fuse and almy dom lights work and for got to mintion that the power not actual power the on wire idr what it is actualy called wire is going from the fuse box off the constint current terminals
Old Feb 11, 2010 | 05:33 PM
zman17's Avatar
zman17
OMG, whatever. I'm done with this thread. Good luck bud, hope you get it fixed.
jasonw's Avatar
jasonw
Site Moderator
You're going to have to confirm a translation for me. I almost can't make out some of that.
I've got it set up to where I have an on/off switch. Today, after I got out of school, I changed the fuse and my dome lights work. Oh, and I forgot to mention that the main power wire (not the one to the radio fuse) goes to the constant power terminal in the fuse box.
Is that an accurate translation, audioman?
Not trying to be mean or anything, but if you don't use at least a semblance of proper grammar, its awfully hard to understand you.
Old Feb 11, 2010 | 06:52 PM
audioman10's Avatar
audioman10
my bad it works and im happy and my head unit works and im happy thank you guys........
Old Feb 26, 2010 | 02:02 PM
Bran743's Avatar
Bran743
Hmmm.... seems like my thread got hijacked.
So back to the original problem, I've checked all the fuses and none of them are blown. The one next to the shut down is for the park lights. They work like a champ but the cab lights and dome light still don't work. I'm scratching my head here guys. I'm still at a loss on what's going on with this thing. Is there a plug-in type connection some where behind the dash that might have come loose? Thanks.
Brandon
Old Feb 26, 2010 | 02:41 PM
zman17's Avatar
zman17
Could be the switch itself.
