Question on 35" MudRover and Lift
Old Apr 25, 2005 | 01:06 PM
fabianva's Avatar
fabianva
Default Question on 35" MudRover and Lift
Hi...First post here.
I just bought a 94 Ram 1500 that has a 4 inch lift w/ 35" Dunlop Mudrover tires. I wanted to know if I might be able to lower the truck and still keep the 35" tires. If I can, what's the lowest I can go and still have clearance for these tires. Currently the truck is a bit too tall for my taste but I don't want to invest much into the truck since this is a weekend truck. Here's a picture.
Thanks.
FL
[IMG]local://upfiles/15261/69CB53EF798C4FF79DA0CCE0966E776C.jpg[/IMG]
Old Apr 25, 2005 | 02:40 PM
hometheaterman's Avatar
hometheaterman
Default RE: Question on 35" MudRover and Lift
I don't think you can go any lower as I have a 3" lift with 33"s and they don't rub and I could go to 35"s in the rear but I'm pretty sure in the front it would rub as the 33"s at full turn are pretty close and I don't think I would get 35"s on there without rubbing I'm kind of suprised the fit ok with 4" lift but then again you have flares that may help that and your wheels may not have as much backspacing as mine.
