I have a hunch on why I get such bad MPG
Old Feb 14, 2010 | 09:53 PM
2001Ram's Avatar
2001Ram
Default I have a hunch on why I get such bad MPG
I just filled up, and I am getting 10 MPG, and I have been driving it like an old lady.and when I did the plenum, I put a Stant 195 degree thermostat in.
I just hooked up my code reader, and it told me this:
It says my coolant is 183 Degrees. Is it possible that the truck is still running in warm up mode, and the 02 sensors aernt working?
Old Feb 14, 2010 | 09:57 PM
PurplDodge's Avatar
PurplDodge
183* sounds normal.
But your front O2 sensor might be shot. Hughes Engines has the best price on NTK sensors I've found. $49 for NTK 23151
Gerehead8's Avatar
Gerehead8
By 183 degrees the computer would have gone into closed loop and the O2 sensors would be working.
Old Feb 14, 2010 | 10:02 PM
pavement_hater's Avatar
pavement_hater
I know why I get such bad mpg's too. I got a 3 ton truck with a V8 engine.
Old Feb 14, 2010 | 10:07 PM
2001Ram's Avatar
2001Ram
hahaha but 10? Really?
Old Feb 14, 2010 | 10:12 PM
2001Ram's Avatar
2001Ram
Well, if that isnt the problem, I guess I will make a trip to Napa tomorrow and get a new distributer cap and rotor.
Old Feb 14, 2010 | 10:17 PM
Oren1500's Avatar
Oren1500
Did you check your cat? My mpg sucks right now and I've done the Hughes plenum, cat is most likely plugged up so I'm gutting it tomorrow.
Old Feb 14, 2010 | 10:41 PM
sit22 II's Avatar
sit22 II
was the truck fully warm when u checked it ?
if yes i would say try a new temp sensor for the computer...
Old Feb 14, 2010 | 10:47 PM
PurplDodge's Avatar
PurplDodge
Why do you say that?
Old Feb 14, 2010 | 10:52 PM
2001Ram's Avatar
2001Ram
I havent checked my cat because I dont know how, and because my truck has 75K miles on it. I doubt it bad.
I dont think my temp sensor is bad.
Yes, truck was fully warmed up, and it was 42 degrees outside.
