still leaking trans fluid + coolant
Old Feb 19, 2010 | 05:13 PM
lblair04's Avatar
lblair04
I had a coolant leak and started throwing parts at it. Thermostat housing gasket was leaking, so I replaced that. Still had coolant leaking. The only spot I could see it going to was the back of the engine and around the axle. Ended up being the timing chain cover. Replaced that, along with new water pump and timing chain and havent had any leaks since.
