air/fuel mixture gauge install
Old Feb 22, 2010 | 07:08 PM
01greenram's Avatar
01greenram
Default air/fuel mixture gauge install
i have searched for this in here im installing a air fuel gauge do you guys know where i put the voilet wire on the o2 sensor
Old Feb 22, 2010 | 07:39 PM
01greenram's Avatar
01greenram
i know someone has one of these i bought the automter pro comp2 electric and all i can get is 1 bar on the rich side
Old Feb 22, 2010 | 07:42 PM
sit22 II's Avatar
sit22 II
correct me if im wrong but dont you need a second 02 sensor for the gauge to work right?
and what brand is it?
Old Feb 22, 2010 | 07:50 PM
01greenram's Avatar
01greenram
autometer and no not that i know of
Old Feb 22, 2010 | 07:59 PM
01greenram's Avatar
01greenram
what color is the wire i cut in to
Old Feb 22, 2010 | 09:42 PM
Gerehead8's Avatar
Gerehead8
You can't install a AFR gauge on the stock O2 sensor. The stock sensor is a narrow band sensor and only shows <14.7 =14.7 or >14.7. You need to get a wideband O2 sensor and controller to use that gauge. Unfortunatly the wide band and controller are $200+. Innovate sells good quality ones.
Old Feb 23, 2010 | 01:43 AM
RM_Indy's Avatar
RM_Indy
You can get a reading off the narrow band, just wont be accurate WOT, need wide band for that. Few years back I was tuning my MP PCM with an SMT6 piggyback. I was getting the signal for the smt6 a/f from my stock narrowband, I also had(still have) an AEM digital a/f with Bosch wide band o2 (FAST wb also now). Closed loop the narrow band readings were almost identical to the wideband readings. WOT though the narrow band was erratic compared to the wideband readings.
Ill see if I still have my schematics for the smt6 & what wire I pulled the signal from.
Old Feb 23, 2010 | 02:13 AM
01greenram's Avatar
01greenram
the sensor is for a narrow band o2 www.jegs.com/i/Auto+Meter/105/4375/10002/-1
Old Feb 23, 2010 | 02:40 AM
BlueBeast2's Avatar
BlueBeast2
Indy question for ya. On my wide band when I let off the gas it goes lean which is gonna happen. Is there a way to tune for it not to do that or is that ok? I'm new to all this stuff
Old Feb 23, 2010 | 01:25 PM
01greenram's Avatar
01greenram
i still cant figure this out i called autometer and they said call dodge and dodge said call autometer wtf?
