pinion seal
Old Feb 22, 2010 | 07:30 PM
duck Blaster's Avatar
duck Blaster
Default pinion seal
pinion seal leak .have haynes book tells me to measure inch # on pinion turning have wheels and drums off ,driveshaft unhooked ,spin nut with companion flange still attached spins free by handd .NOW WHAT 1999 1500 WITH 9.25 DIFF.LSD 4X4 ..HELP PLEASE
Old Feb 23, 2010 | 08:51 PM
Pip10's Avatar
Pip10
When I did my front pinion seal all I did was mark the nut, shaft and yoke then count the number of turns it took to get the nut off. Reassembly was then just install the yoke on the shaft (marks aligned) then screw the nut on counting the same amount of turns. In the end just tighten the nut so the nut and yoke marks line up. Haven't had any problems since. No whining noises form the front diff and no more leaks from pinion.
Old Feb 24, 2010 | 12:52 AM
duck Blaster
Default Pinion seal
Thanks for allINFO .i DID ALL THAT same thing my problem i think my bearings are wore out .235000+ miles .Pinion shaft has some play in it .
Old Feb 24, 2010 | 12:56 AM
duck Blaster
im new to this site trying to figure out how to navigate .can anyone tell me shortcut to diy site? thanks yea im not much of a typing ace
Old Feb 24, 2010 | 01:04 AM
95_318SLT's Avatar
95_318SLT
All you have to do is tighten the pinion nut down to 210 ft*lbs.
