transmission will not go into gear from shift lever
Old Feb 23, 2010 | 01:50 PM
snipenyou's Avatar
snipenyou
Default transmission will not go into gear from shift lever
ok i have a 1996 dodge ram 1500 4x4 and i just put a transmission in when i put transfer case in it went on like it suppose to. took linkage off trans and tryed to move with hand no go. what if i loosened transfer case bolts and jiggled transfer-case? maybe shifter rod is hung up? any help before the next snow fall would be great thanks guys no suggestions at all come on guys no one knows anything?
