Name this transmission sensor (pic inside)
Old Feb 26, 2010 | 01:58 PM
93blackta's Avatar
93blackta
Default Name this transmission sensor (pic inside)
Towards the end of the tailshaft. The transmission in the truck has it and the replacement I bought does not.
Old Feb 26, 2010 | 01:59 PM
95RAM360's Avatar
95RAM360
did you make the thread on the 98 tranny in a 97? if so i told you to look and make sure both had the sensor on the tailshaft.....your going to need to get the right tranny i believe, and thats for the O/D if im not mistaken
Old Feb 26, 2010 | 02:19 PM
yakkier's Avatar
yakkier
either a OD sensor or speed sensor
Old Feb 26, 2010 | 02:21 PM
Sheriff420's Avatar
Sheriff420
That is the speedometer gear on a 94-97 Ram.
Old Mar 16, 2010 | 10:56 PM
95SilverBullet's Avatar
95SilverBullet
Question Name this sensor too!
Forward and a little lower than the sensor that is labeled in this photo. You can only see part of it here, since the cross-member is in the way. Any help would be appreciated!
Old Mar 17, 2010 | 02:01 AM
J415's Avatar
J415
That's called the output speed sensor. It's a $16 part.
