e-fan control kit
Old Feb 27, 2010 | 03:47 PM
BigRedRam95's Avatar
BigRedRam95
Default e-fan control kit
Hey guys I am almost ready to start all my upgrades and need a fan control kit I don't want one that has the probe that sticks into the rad I want one with a thread in thermostat. This is the one I think I want. http://www.summitracing.com/parts/DER-16749/ But does any one know where I could put the stat? I was thanking about the neck that goes over the stock stat but will it fill clear up with anti-freeze?
Old Feb 27, 2010 | 05:11 PM
BlueBeast2's Avatar
BlueBeast2
Are you running 1 fan or 2? Why do you want an adjustable one?
Old Feb 27, 2010 | 05:28 PM
BigRedRam95
I am only going to run one for now but I thank I can run one or two with this one that way if I need two I can add one later. I want an adjustable one so if I run a 180 stat I can make the fan come on at 180 or 185 and if I run a 195 stat I can make the fan come on a 195.
Old Feb 27, 2010 | 06:57 PM
BlueBeast2's Avatar
BlueBeast2
I know it says you can run 2 but keep this in mind
Fan amperage is critical with this unit, most dual fans with large amperage draws will require the use of two controllers.
I have this one and so far it has been great http://www.summitracing.com/parts/SUM-890014/ I'm running a 180 t-stat. Not sure if you remember hutch but he was big into fans. Testing fans was his profession. He said my setup would be better then a adjustable one. I forget now why he said to not use a adj one though.
I had my air gap drilled and tapped for the sensor. Do to where I put it I had to drill my accessory bracket as well but it works.
I don't think the water neck would be a good idea
Old Feb 27, 2010 | 09:23 PM
BigRedRam95
I bet I could drill my stock keg that I did the kegger mod to while I have it off
