4x4 suspension on 2x4
Old Feb 28, 2010 | 08:57 AM
RonRacer's Avatar
RonRacer
Default 4x4 suspension on 2x4
hi guys, i was just wondering if i could use the 4wd springs to lift my 2wd.....i just want the 4wd stock hieght(the ladies in my life are too short for anything higher). and i saw 2 4x4s in the j/y the other day....
Old Feb 28, 2010 | 09:32 AM
halfamil's Avatar
halfamil
Would somebody clue me in on what "j/y" is.
Old Feb 28, 2010 | 09:37 AM
BigRedRam95's Avatar
BigRedRam95
I thank it is junk yard
Old Feb 28, 2010 | 09:59 AM
halfamil's Avatar
halfamil
Makes sense.
Old Feb 28, 2010 | 12:25 PM
Maxx_Magnum's Avatar
Maxx_Magnum
j/y IS junkyard.... I thought everyone knew that
Old Mar 2, 2010 | 09:43 PM
RonRacer's Avatar
RonRacer
so now that we have that cleared up....any suggestions??
Old Mar 2, 2010 | 09:47 PM
yakkier's Avatar
yakkier
You might have some problems because we have solid axles on the front, and you have spindles. Not sure if they would work
Old Mar 2, 2010 | 09:50 PM
PurplDodge's Avatar
PurplDodge
No, you have IFS and 4x4s have a solid axles. There are two whole different suspension types, ans with them different loads and geometrys that are put on the springs.
And 2x4 is a piece of wood, you cant put a suspension on that.
Old Mar 2, 2010 | 10:04 PM
dodgeram07's Avatar
dodgeram07
to answer your ? i dont belive so,, best bet spring spacer and cheapest
Old Mar 2, 2010 | 10:21 PM
EndIsNear's Avatar
EndIsNear
And 2x4 is a piece of wood blah, blah blah and I think every lifted 2WD truck out there is considered a B.A.M.F. Truck, and that you CAN put a suspension on that.
I fixed that for you .
You can go with spacers to give you the 4X4 height you want.
1", 1.5", 2", and 2.5" (maximum.)
I don't believe you can use 4X4 coils, but maybe some 2WD 3/4 ton or 1 ton springs
