You might want to check your pvc.. valve that could be your problem and you should go get some muffler bearings why your at it always good to change them together
Pvc. Hmmm, I got some laying out in the back yard. Will that work?
Originally Posted by yakkier
change your muffler bearings, also could be your blinker fluid
Just changed the blinker fluid, Change it every 3K miles.
Originally Posted by halfamil
I'd jack the steering wheel up, and pull another truck under it!!!
Sounds to much like work?
Originally Posted by Kaldir
Yeah really, maybe one of your 4 transmission went bad, I would check all four out.
Now, Do you remeber me talking about that or just a lucky guess? I have had 4 trannys. Dumb a$$ stealership.
Your going to need a big wrench. the bolts are like 7/8. They where put in with a impact drill. The thing was smoking when we got done. =D
Btw, All lights are functional.
Then theres the viper alarm. I dont know if the installers made it way sensitive but lightning used to set the thing off, Like the stuff that vibrates the ground, Yea, That. It was annoying, I was like 9-10 and it would go off at like 3 am. I never slept good in storms.
