electrical problem 01 Ram
Hi guys,
I've got some sort of electrical problem I could use a little help with.
I have a 2001 dodge ram 1500 2wd with the 318 motor.
My truck will start and run perfect for 5 or 10 minutes then just like you turn off the key it shutsdown. Then a few hours later it will do the same thing start up run great shut down. Can't trust it to drive anywhere.No check engine light on,I have swapped out the asd relay,don't really know what sensor might be the problem. It kills power to fuel pump ignition system an and dash guages. sometimes it takes as long as 2 days before it will start again. It's driving me nuts sure could use a little advice with this problem.
Thanks
Ray50
Thanks
Ray50
