brake problems
Old Mar 6, 2010 | 05:47 PM
NDRS4x4's Avatar
NDRS4x4
Default brake problems
My brakes lines are starting to rust out, so I decided to replace them from the master cylinder all the way back. Now when I try to bleed them I cant seem to draw the fluid out of the master any thoughts. Also does anybody have any pictures of their master cylinder and attached lines, i want to make sure mine are all connected right.
This in on a 99 1500 5.9 4x4
Old Mar 6, 2010 | 05:51 PM
yakkier's Avatar
yakkier
if you replaced the lines and mastercyl, if the lines are still dry, loosen all 4 bleeding screws on all 4 corners of the truck and have some one pump the brakes untill you see fluid coming from the bleeds.
Dry lines should empty the mastercyl when they are all primed. just dont forget to refill the mastercyl when ur done
