I need some advise Is my truck level or a wheelie machine.
Old Mar 7, 2010 | 04:01 PM
rwilhelms's Avatar
rwilhelms
Default I need some advise Is my truck level or a wheelie machine.
So I put my lift in this weekend 3 inch coil spacers in the front and 4 inch blocks in the rear. I didnt want to stack blocks so I took the stock ones out so It was only lifted 2 inches in the rear. Well I thought the truck would sit level but looking at it im not sure. And it seems like everyone i ask varies. So I figured Ill ask here should I put another inch or two in the rear or does it look good?
URL=http://img687.imageshack.us/i/gedc0188.jpg/][/URL]
URL=http://img651.imageshack.us/i/gedc0189.jpg/][/URL]
Old Mar 7, 2010 | 04:03 PM
01Green5.9L's Avatar
01Green5.9L
To me it looks like it's setting a little low in the back.
Old Mar 7, 2010 | 04:06 PM
jasonw's Avatar
jasonw
Site Moderator
Looks a tad lower in the back to me.
Maybe your springs are sagging a little. I'd either add another inch or so in the back, or get 2 inch coil spacers.
Old Mar 7, 2010 | 04:07 PM
DukesOfHazzard's Avatar
DukesOfHazzard
On the sec pic IMO i could tell the fronts a tad higher, not much depends on if it's gonna make that much difference and drive you crazy.
Old Mar 7, 2010 | 04:08 PM
dhvaughan's Avatar
dhvaughan
rear end needs more lift. i'd stack the blocks. iron's iron.
Old Mar 7, 2010 | 04:09 PM
DukesOfHazzard
What about AAL instead?
Old Mar 7, 2010 | 04:10 PM
rwilhelms's Avatar
rwilhelms
i think ill just get an inch block for the back or get longer u bolts and put the stock blocks back in. Do u think 2 inches would be to big
Old Mar 7, 2010 | 04:14 PM
dhvaughan's Avatar
dhvaughan
measure from the ground to the rim of the fender well. use a jack in the rear to bring it up to where you want it. it depends on your preference, but i like the rake look of a slightly higher rear.
Old Mar 7, 2010 | 04:15 PM
01Green5.9L
I think 2" would be just about right
Old Mar 7, 2010 | 05:43 PM
meanwhitemopar's Avatar
meanwhitemopar
stack blocks is nto good... its ok, but not good...
it does look a little lower in the back... put your 3 inch block in, add a 3" AAL... should sit good
