Starter wire
Old Mar 8, 2010 | 09:07 PM
Robertb6963's Avatar
Robertb6963
Default Starter wire
Where does the smaller gauge wire running from the starter run? It has a connector on the end of it that doesnt fit itno any other connector I have. I currently have to use a remote starter switch ( http://www.amazon.com/Actron-CP7853-.../dp/B0009XQUKW )to start the truck(jumped between the battery and the wire running up from the starter). The key will not start the truck. This is a swapped in motor and I sold the donor truck already do I cant look back at that truck for ideas!
Thanks!!!
Old Mar 9, 2010 | 07:40 PM
Robertb6963
...bump...any ideas?
Old Mar 16, 2010 | 08:28 PM
Robertb6963
I ended up just running a wire from the stater and a wire from the power dist block the a toggle switch on the dash. It works for now, but sure aint the right way to do it lol.
