Pic of my transfer case
Old Mar 11, 2010 | 12:17 PM
White Ram's Avatar
White Ram
Default Pic of my transfer case
The back of my transfer case doesn't look like the one in the Hayne's manual. Where are the drain and fill plugs?
Old Mar 11, 2010 | 12:26 PM
95RAM360's Avatar
95RAM360
right below the tag is the plug i believe....mines the same set up and i have to check my fluid as well, but thats where i was going to check.
Old Mar 11, 2010 | 01:27 PM
Gerehead8's Avatar
Gerehead8
Yep under the tag is the fill/check plug and the drain plug is on the bottom left (it is the same style plug). Mine where a PITA to get off so now I welded a nut to the back of them that makes it easy to remove.
Old Mar 11, 2010 | 03:00 PM
meanwhitemopar's Avatar
meanwhitemopar
LMAO, i did the same thing last time i had mine apart, i welded a think its a 5/8 nut on both... just so i can have it easier next time i do it
Old Mar 11, 2010 | 05:02 PM
95_318SLT's Avatar
95_318SLT
Here you go. And the plug requires a 30mm (I think?) socket. And I've never had a problem getting mine off.
Also, it looks like your drain plug could use a new seal.
DSCF2184.jpg?t=1268344943
