wheel spacers
Old Mar 12, 2010 | 02:30 AM
bucksplitter's Avatar
bucksplitter
Default wheel spacers
any body ever use wheel spacers just wandering if they are safe i just got this truck about a month a go and it came with brand new bfg 315/75R16 scrubs if i turn the wheel all the way ripped one of the lugs off i Lent my lesson but my my wife wants to drive it and she want pay attention liable to rip the whole tire off and on more thing how can you tell if the suspension is stock?
Old Mar 12, 2010 | 05:06 AM
97tn4x4's Avatar
97tn4x4
If you're rubbing your control arms that bad and you put spacers on it you're just gonna rub your fenders. You need at least a 3" lift for that size tire. I've run spacers on other vehicles and had no problem. But it will be more strain on your wheel bearings and balljoints. As far as the suspension goes by looking at your sig it doesn't appear to be lifted cause those tires look stuffed in there but post some pics and it would be easier to tell. You can look for spacers above the coil springs, our stock control arms are pretty much c-channel and most aftermarkets are round, a much bigger than stock overload on the leadsprings. Those are just a few things.
Old Mar 12, 2010 | 07:15 AM
dhvaughan's Avatar
dhvaughan
on/around the steering knuckle? is an adjustable stop. you might move it a little or weld on more stop.
don't let the wife drive the truck....
Old Mar 12, 2010 | 07:31 AM
97tn4x4's Avatar
97tn4x4
don't let the wife drive the truck....[/QUOTE]
+1 on that
Old Mar 14, 2010 | 12:32 AM
bucksplitter
eventually i will lift at least 3inches then it will be to high for to get into the truck
