OD switch
ok, i got my truck back finally... the one thing i know needs to be replaced is the switch on the column that turns the overdrive off....
my queston is, do i have to replace the whole column, or the shifter, or can i take that end apart and do jsut that?
ok....as far as i know...dont quote me.....you can just change the switch. it pops right off the shifter and i believe you just cut the wires and solder the new ones in. ill look into it, my buddy changed his 2x so i will check when i see him later tonight at the fire house and get back to ya. i hope that trans has finally had enough of giving you a hard time and just acts right now. best of luck with it
