think my Heater core just crapped out
Old Mar 13, 2010 | 06:19 PM
95RAM360's Avatar
95RAM360
Default think my Heater core just crapped out
Went for a drive tonght, and i think my heater core shat the bed...When i shut off my truck the windows fog up very quickly, the is some moisture on pass. floor, but it was only one squirt...and when i turn the wheel it sounds like waters dumping onto the fan, and it will come out of it...but when i turn the wheel again, the water on fan sound happens again...
Now I knowthe common problems for heater core are the windows fogging, an moisture on pass. floor, but i wanted to varify because my heat still works great, and theres very little moisture on the floor...any help would be great...thanks.
Old Mar 13, 2010 | 06:30 PM
Ram_Me's Avatar
Ram_Me
If there's fogging and dripping, it's the heater core. The water on fan thing could be from the heater hose on the water pump being ripped or something. Maybe you have a clogged core, and the pressure built up and busted the hose. Maybe it only leaks on the fan because the power steering is being used and putting stress on the water pump because the stress on the belt or something.
I hope all this makes SOME sense..
Old Mar 13, 2010 | 06:35 PM
xxxcowxboyxxx's Avatar
xxxcowxboyxxx
try flushing it first before replacing it, like stated about it is very possible it got clogged, happens alot
Old Mar 13, 2010 | 06:36 PM
95RAM360's Avatar
95RAM360
damn...i dont want to rip the dash apart again lol...last time i gave my dash a good 3in crack when i took it out...and it was mint before....might as well replacdash at same time if i break it anymore
there is a gurgle...but my heat is HOT
Old Mar 13, 2010 | 06:37 PM
Ram_Me's Avatar
Ram_Me
Yeah, start with that flush. Do it several times. Check your hoses too.
Old Mar 13, 2010 | 06:40 PM
95RAM360's Avatar
95RAM360
i have all new hoses (all within 4 months) Thermo hose, bypass hose, and the bottom hose are all new...is there one im missing??
Old Mar 13, 2010 | 06:45 PM
Ram_Me's Avatar
Ram_Me
There's another one right next to the driver's side valve cover, it's also connected to the waterpump.
Old Mar 13, 2010 | 06:47 PM
Ram_Me's Avatar
Ram_Me
Actually, there's one next to both valve covers. The passenger side one connects to the intake manifold.
Old Mar 13, 2010 | 06:52 PM
95RAM360's Avatar
95RAM360
yes i know of the small one, i replaced the o-ring on that spout a well...but that line i havent changed, should i follow that line to se if theres leaks?
Old Mar 13, 2010 | 07:04 PM
Ram_Me's Avatar
Ram_Me
Yeah, do that before you even bother flushing it.
