steering loose??
Old Mar 14, 2010 | 01:09 AM
VinsBlackRam's Avatar
VinsBlackRam
Default steering loose??
Does anyone know what can be the cause of my loose steering? i have a little bit of loose steering and it gets real dangerous wen im goin around 60. and wen i get it up to the 110 115 area it gets realy scary.
Old Mar 14, 2010 | 01:37 AM
rumble_truck's Avatar
rumble_truck
Easy fix, don't go 115 in a full-sized pickup.
Old Mar 14, 2010 | 01:58 AM
DukesOfHazzard's Avatar
DukesOfHazzard
https://dodgeforum.com/forum/2nd-gen...djustmant.html It could be numerous steering componets, but i did this and it helped a-lot , now I dont look like a drunk driver going down the road, lol
Old Mar 21, 2010 | 10:19 PM
MattV's Avatar
MattV
I just did this adjustment.
It says don't overtighten as to not to "Bind".
Maybe this sounds stupid but how do you know if you are "binding"? will you hear it?
The reason I ask is because I had about 2-3 inches of play in my steering wheel and I adjusted it the way it said to but went about 1 to 1 1/4 turn I am thinking and the hex bolt would not turn anymore. But now my steering is nice and tight. But because I drove it loose so long I can't tell if it is too tight or not. It seems fine with the exception I noticed I have a upper ball joint which puts some play into my steering and will fix that this week, but other than that play it feels "tight" but not "binding" I guess?
BTW very simple to do. I was shocked how easy it was. So easy it almost scared me!!!lol
Old Mar 22, 2010 | 12:33 AM
iwhitne's Avatar
iwhitne
I had this problem too...
I replaced the track bar.. upper and lower ball joints
inner and outter tie-rods $170
inner and outter tie-rod ends $90
tie-rod adjusting sleeves $30
new tires $389 (re-treads)
alignment $60
steering dampner $60
she drives straight as an arrow
Old Mar 22, 2010 | 12:51 AM
Maxx_Magnum's Avatar
Maxx_Magnum
welcome to the club guys!
Mattv, you will know if it's too tight if it won't return to center after turning... It would kinda 'stick' wherever it's turned to... if it's working fine then you are probably ok
