DIY Dana 60 swap for 1500
Old Mar 15, 2010 | 09:58 AM
ITTTom's Avatar
ITTTom
Thumbs up
Originally Posted by WaynesWorld
nice work! I am subscribed (c:
Same here
Old Mar 15, 2010 | 10:07 AM
quackaddict's Avatar
quackaddict
Any info on the axles themselves? What years will swap directly in without modification etc, I needed this DIY thanks a million.
Old Mar 15, 2010 | 04:28 PM
SpcD1500's Avatar
SpcD1500
You can use any 94 - 02 dana 60 without modification, I do believe the 2500 and 3500's with the tow package came with dual piston calipers (if im wrong someone correct me) so that may be something you would want to hunt for if you want the best brakes. But even the standard brakes are a good bit bigger then the 1500's. Other then that the suspension mounts are the same thing just welded to a stronger axle
Correction: Sorry but ifergot about this piece of info. In 1998 dodge switched to a different sway bar that had a different mounting brakst on the axle end. This wont cause anything else not to work but just make sure if you have a pre-98 truck and are getting the axle out of a post-98 to get the swaybar also and vice versa or order a new one.
Again if i missed anything else please correct me, and makesure you guys that have already read this to look at the first post again cause i added alittle bit of info about the installation side of the swap.
Old Mar 15, 2010 | 07:10 PM
jasonw's Avatar
jasonw
Site Moderator
Nice job.
Copying this thread to the DIY section. If anything changes here, let me know, I will change it in the FAQ as well.
Old Mar 15, 2010 | 07:25 PM
SpcD1500's Avatar
SpcD1500
Thanks Jason, as a mod do you thing i should make a second thread when i do my rear axle or just add it to this one?
Old Mar 15, 2010 | 07:58 PM
Maxx_Magnum's Avatar
Maxx_Magnum
Nice write up man!!! A lot of people are gonna appreciate this! possible myself included
Old Mar 15, 2010 | 08:24 PM
SpcD1500's Avatar
SpcD1500
No problem, if i make it easier for one person then it will be worth it
Old Mar 15, 2010 | 10:38 PM
jasonw's Avatar
jasonw
Site Moderator
IMO, I'd say make a second thread.
When it comes time, if I don't jump into the thread right away, PM me. That way, when I get time, I'll make sure and add it to the FAQ as well.
Old Mar 15, 2010 | 11:29 PM
SpcD1500's Avatar
SpcD1500
sounds good
Old Mar 17, 2010 | 08:25 AM
mnewbolds's Avatar
mnewbolds
Nice DIY my friend. I'm looking into doing this but my concerns are the rear axle swap. Dana 60's front and rear? I have all stock suspension, would it be worth it to upgrade to 2500 springs? I would imagine the heavy axles would cause premature failure of some of the stock parts.
