14x3 Edlebrock
Old Mar 16, 2010 | 09:48 PM
PurplDodge's Avatar
PurplDodge
Originally Posted by Twisted Metal
Yes Mud, that is what you need. The spacer sits on top of the TB. It keeps the lower dish of the 14x3 from hitting the throttle/cc linkage.
If you get the right air cleaner, you wont need that. I have an Edelbrock with a stamped bottom and it doesnt hit the throttle body.
Old Mar 16, 2010 | 10:18 PM
Cheek-oh!'s Avatar
Cheek-oh!
i got the 1" spacer for my spectre. it looks bad ***....
Old Mar 16, 2010 | 10:28 PM
Mudshack's Avatar
Mudshack
Will I still need to bend a bolt?
Old Mar 16, 2010 | 10:34 PM
mbrinegar57's Avatar
mbrinegar57
yes u will
Old Mar 16, 2010 | 10:35 PM
Cheek-oh!'s Avatar
Cheek-oh!
yeah. 3/4 off center
Old Mar 16, 2010 | 10:36 PM
mbrinegar57
i think you got the same air cleaner i did from oriellys if so u wont need the spacer
Old Mar 16, 2010 | 10:40 PM
Mudshack's Avatar
Mudshack
Dang. Don't have a bench vice. Gonna have to plan for that. Was hoping for a plug and play situation.
Old Mar 16, 2010 | 10:45 PM
Cheek-oh!'s Avatar
Cheek-oh!
its simple. i bent mine with a wrench... and after that, you got to cut it 4 1/2 inches if you have a stock throttle body. other than that it is pretty much plug and play....
Old Mar 17, 2010 | 07:46 AM
Flue's Avatar
Flue
vise? Nah....1x6 (that's like a 2x4 only not ) 4 screws and a tape measure. 1/4" all thread is pretty easy to bend.
2 screws little more than 1/4" apart, insert all thread, measure up to your first bend, insert screw (I used what was on hand, 1" sheetrock screws), bend. This is for the 1" offset. Measure and insert 4th screw. Bend. Cut both ends if you need to, till your S-bolt is correct length. Install 14x3 air hat and your good to go.
or grab some pliers. But you won't need a vise.
Old Mar 17, 2010 | 09:31 AM
Mudshack's Avatar
Mudshack
LOL....thanks guys. I was going to use big pliers and the edge of the driveway, but the screws and board idea sound great!! I will go look up the measurements for the bolt in the FAQ section.
