ac pump making funny noises
Old Mar 17, 2010 | 04:02 PM
rich95ram's Avatar
rich95ram
Default ac pump making funny noises
hi guys , my trucks just started making funny noises every so many seconds the ac pump clicks and makes a funny noises then stops for a minute or so but the problem stops when when the fan is switched off.have any of you had problems like this before.should the air con work on all fan settings?
Old Mar 17, 2010 | 04:08 PM
bigster's Avatar
bigster
go to a service shop and let them measure the pressure of the r134 gas, chances are that you have a leak and you're out of gas in the a/c system. The blower motor switch has 2 sides you can turn, left is with a/c and right without. Also if the vents are in the "defog" position, the a/c automaticly switches on, try to avoid this.
Old Mar 17, 2010 | 04:35 PM
rich95ram's Avatar
rich95ram
thanks for that will get that checked as soon as possible
Old Mar 17, 2010 | 05:02 PM
Kaldir's Avatar
Kaldir
+1 That happens when you have low pressure, or now gas at all.
