engine missfire
Old Mar 18, 2010 | 04:03 AM
master2090's Avatar
master2090
Default engine missfire
i just bought a 99 ram 1500 with the 5.2L v8. when you are driving it feels like the engine miss-fires and chugs every once in a while, like when going from a dead stop or when the truck shifts into overdrive and drops the rpm's down. it only does this a little bit but i know i need to take care of it right away. i only paid $1800 for it and this is the only problem it has, the owner didn't want to deal with it so they decided to just sell it. any ideas where i should start looking for the problem? the owner said they changed the plugs and wires but it didn't stop it from happening.
Old Mar 18, 2010 | 08:33 AM
95RAM360's Avatar
95RAM360
Plenum gasket, or clogged cat
Old Mar 20, 2010 | 09:40 PM
master2090's Avatar
master2090
this is probably a dumb question but what would be the best way to check either one of those without tearing apart to much stuff? should i check anything else first, like maybe have a tune up done? someone told me it might be the distributor or the coil.
