How Much tranny fluid needed?
Old Mar 20, 2010 | 04:06 PM
shadoe's Avatar
shadoe
Question How Much tranny fluid needed?
Hello,
I have just rebuilt my tranny and I have 2 questions:
What is the best method of checking your tranny fluid level? (With truck in neutral ?)
How much fluid is required after a rebuild?
Truck specs:
2001 ram; 3.9 ; V6 ; 42RE tranny ; single cab ; Automatic .
Old Mar 20, 2010 | 08:52 PM
omegax's Avatar
omegax
You have to put it into neutral to check the fluid, as to how much fluid after a rebuild is required i'm not sure but the fluid capacities can be seen in the sticky https://dodgeforum.com/forum/2nd-gen...apacities.html
Old Mar 21, 2010 | 12:00 AM
RamSport97's Avatar
RamSport97
If I recall, it is 11.7 quarts. Yep check the dipstick in neutral once engine is at operating temp.
Old Mar 21, 2010 | 01:16 AM
J415's Avatar
J415
I hope you filled up the torque converter before you installed it.
