Lincoln Lockers Anyone?
Old Mar 21, 2010 | 12:00 AM
97thumpinram's Avatar
97thumpinram
Default Lincoln Lockers Anyone?
Well, this week my spiders went, so I bought another diff. that I'm swapping in. So I'm thinking its time to re-build the old dif. and put 4.10s in. Question is, if I just weld up the spiders in that dif. how well do you think it will hold? It is a 2wd, and I run 265-75-16 tires on it. Its my DD but I end up in muddy and snowy areas fairly often so its time to solve my traction problem. I don't pop the clutch and spin them at every light, but i do play on occasion, so any input guys?
Old Mar 21, 2010 | 02:19 AM
Hahns5.2's Avatar
Hahns5.2
Welded diffs are great for trail rigs that don't see much street but they'll eat up tires if driven much on pavement..
If welded properly, IE: weld the spider gears/side gears and then weld the side gears to the carrier, it will be very strong..
Old Mar 21, 2010 | 03:02 AM
Weldor's Avatar
Weldor
I personally wouldn't do it if its your DD and sees alot of street use, mabey an LSD?
Old Mar 21, 2010 | 08:53 AM
dhvaughan's Avatar
dhvaughan
Originally Posted by 97thumpinram
Its my DD
i wouldn't weld up a road vehicle.
either do an LSD, full locker, lunchbox locker, or nothing.
Old Mar 22, 2010 | 03:59 PM
97thumpinram
Ok, well how well do you guys think a powertrax would stand up to the ocaasional tire warming and playing?
Old Mar 22, 2010 | 04:07 PM
Sheriff420's Avatar
Sheriff420
I was considering a powertrax lockright but there are too many mixed opinions on them. On pavementsucks.com you'll see a few people that love them and never had a problem but you will also see people that have broken a couple and had their gears go out with them. Too big of a risk.
Old Mar 22, 2010 | 04:53 PM
97thumpinram
Well that sucks, cause I need sumthin reliable. Are there any options under 500 bucks that im missing?
Old Mar 22, 2010 | 05:03 PM
JohnnyZJ's Avatar
JohnnyZJ
truetrac?
Old Mar 22, 2010 | 05:35 PM
sungod's Avatar
sungod
For a 2wd you are wasting money on a locker. Unless you plan on drag racing you will never need it unless you like to fishtail.
Old Mar 22, 2010 | 05:46 PM
Sheriff420's Avatar
Sheriff420
I've heard that powertrax no slip is reliable.
