View Poll Results: Should I change my trans fluid?
Yes, You should change it.
92.31%
No, you shouldn't
7.69%
Other, See below in post.
0
0%
Voters: 13. You may not vote on this poll
Changing trans fluid.
Old Mar 21, 2010 | 11:20 PM
Cheat's Avatar
Cheat
Default Changing trans fluid.
Do you think it will be ok to change it?
Its got about 100k-110K on the trans. Do you think it will crap out after I change it? Ive heard of people changing it and there trans start slipping and crap cuz it had so much crap in the fluid it was grabing with that? Any ideas?
Old Mar 21, 2010 | 11:30 PM
Salex007's Avatar
Salex007
ive heard mixed reviews, my opinion is probably not to do that since so many miles and if it is the first one, i like to flush mine every 2 summers which is around 10k miles i put on in that time
Old Mar 21, 2010 | 11:53 PM
PurplDodge's Avatar
PurplDodge
What the hell would it hurt to change the fluid? That makes no sense.
Change the fluid and filter every few weeks and then add an external filter....Or just flush it.
dhvaughan's Avatar
dhvaughan
absolutely change it and refill with atf+4. if the pan has a heavy coat of sludge, then repeat the fluid and filter change again after about 1 or 2 weeks. its my opinion that the new fluid puts the sludge back in solution and then stops up the new filter. that's why people experience failures after a long overdue service
Old Mar 22, 2010 | 12:02 AM
J415's Avatar
J415
There's only one way to find out. DO IT, then get back to us...
Old Mar 22, 2010 | 12:33 AM
dodge15004x45.9's Avatar
dodge15004x45.9
This thread is like some kind of thread I would make. Stupid and point less.
Old Mar 22, 2010 | 12:40 AM
Cheat's Avatar
Cheat
Yea, I dont got 1.5K for a rebuild right now. Neither does my dad.
So everyone think it ok?
Old Mar 22, 2010 | 01:07 AM
RamSport97's Avatar
RamSport97
Yes, change it. Mine hasn't been changed for 50k+ miles, and I am about too. I am going to get it flushed first, drive it home, and immediately drop the pan and change the filter, and top off. This way I get all of the old fluid, sludge, and particles out.
Old Mar 22, 2010 | 01:24 AM
DukesOfHazzard's Avatar
DukesOfHazzard
I'ts not gonna fix itself or do anygood leaving that old broken down crap in there, kinda like not changing your motor oil I would do it a few times, i know the fluid would get spendy , but not a rebuild tranny spendy
Old Mar 22, 2010 | 01:27 AM
Salex007's Avatar
Salex007
well then as stated above looks like it cant hurt
