Another trans check valve option
Old Mar 22, 2010 | 04:41 PM
Sport1500's Avatar
Sport1500
How hard is it to drill out? Is there a write up for that?
Rob
Old Mar 22, 2010 | 11:25 PM
PurplDodge's Avatar
PurplDodge
Rob
Step 1 Remove line
Step 2. Drill the check ball out.
Step 3 Charge someone $48 for it
Old Mar 23, 2010 | 01:27 AM
CPTAFW163's Avatar
CPTAFW163
I bet the check ball was engineered to last 36,001 miles.
Old Mar 23, 2010 | 03:00 PM
dodgeram07's Avatar
dodgeram07
but seening the problems that pcfixer had that seen like a fair price
Old Mar 23, 2010 | 04:25 PM
Sport1500's Avatar
Sport1500
Do you guys see any issue with taking the line apart when the transmission fluid is changed and making sure the check valve is working properly, but leaving it in place?
Rob
Old Mar 23, 2010 | 04:41 PM
CPTAFW163's Avatar
CPTAFW163
Rob
The only issue is PESSIMISM from everyone here on this forum that it WILL EVENTUALLY FAIL and cause tranny death.
It seems that owning one of these trucks is a lifelong lesson in problem solving and the quest to build a perfect 2ndGen how it SHOULD HAVE been built from the factory (aluminum plenum plate, check valve delete, kegger divider delete, pcm reprogram due to deathflash).
Old Mar 23, 2010 | 05:05 PM
Sport1500's Avatar
Sport1500
Yeah I have noticed that. I am coming to this truck from an 88 Toyota 4 cylinder truck where the only thing you had to watch for was the timing chain/guides wearing out every 100,000 miles lol.
Rob
