tranny cooler line size
Old Mar 23, 2010 | 07:13 PM
contractorben's Avatar
contractorben
Default tranny cooler line size
Hi,
What size transmission cooler lines are on my 2001 ram 1500 5.9 4x4. I believe they are 3/8 not for sure truck is at shop. Ordering a trannsmission temp gauge now. I want the compression style fitting, that goes on cooler line. Needs to go from line size to 1/8 npt. A link would be great.
Thanks,
Ben
Old Mar 23, 2010 | 07:35 PM
dodgeram07's Avatar
dodgeram07
well this dont answer you ?....... but you want to put the sender in the front servo port
Old Mar 23, 2010 | 07:43 PM
dhvaughan's Avatar
dhvaughan
Old Mar 23, 2010 | 08:29 PM
contractorben
No, the servo port doesnt give you the best read of temp. of the system, line out to cooler is where I will install. Thanks dhvaughan
Old Mar 23, 2010 | 08:34 PM
Gerehead8's Avatar
Gerehead8
It is 3/8 line and the fittings that attach to the flared ends are JIC fittings. They may be difficult to find.
Old Mar 23, 2010 | 08:40 PM
contractorben
I was just going to cut line and put tee in, they make one I believe.
