got some questions about swaping parts.
Old Mar 25, 2010 | 04:25 PM
broncomitch's Avatar
broncomitch
Default got some questions about swaping parts.
what would i need to do to swap out my really gay steering wheel for a newer one? ( has the cruse buttons on the bottom of the wheel)
both air bag.
and what would i need to swap in a overhead console and have it work?
its a 1997 ram 1500 4x4
Old Mar 26, 2010 | 02:46 AM
99dodge318's Avatar
99dodge318
yeah i have been thinking about doing the same but mine has no cruise.
i really liked the steering on my 05 neon.its the same one thats in the header at the top of the page^^^
Old Mar 26, 2010 | 07:27 AM
Skab's Avatar
Skab
They have air bags in them also don't they? That could be tricky you would need to remove the airbag cover, then the airbag, then the big nut and then you ussualy need a big puller as the steering wheel itself is on a splined shaft.
Of course you need to de-activate the airbag first or you'll get the pieces in your face to say the least.
Old Mar 26, 2010 | 01:39 PM
PurplDodge's Avatar
PurplDodge
Yeah, its possible, I mean these trucks use the same steering columns. Just take it off and swap. Simple enough?
Take the negative cable off the battery then wait 2 minutes for the airbag capacitor to drain.
Old Mar 26, 2010 | 01:40 PM
clipper77's Avatar
clipper77
^ Agreed, I picked up a steering wheel puller at Sears when I replaced my clock spring (cost around $20 i think). Make sure you disconnect your battery and wait a few minutes for the charge in the airbag system to dissipate before servicing, like Skab said, if you don't de-activate the airbag first, you'll wind up getting your face crushed.
Sorry Purpl, didn't refresh before I posted.
Old Mar 28, 2010 | 01:13 AM
broncomitch
pulling the wheel is nothing. im just worried the plugs and what not wont work, ill be pulling mine most likely out of a 99 dakota or durango.
guess ill just pull it all and see....
not sure about what to do about the overhead console.
Old Mar 28, 2010 | 02:44 AM
Maxx_Magnum's Avatar
Maxx_Magnum
I took the airbag equipped wheel of an old Beretta I had without incident..... put a Grant signature series wheel on in its place...... just make sure you use extreme caution! I'm scared to death of those damned airbags
