nubie with stupid questions
Old Mar 26, 2010 | 03:37 PM
j_mccans's Avatar
j_mccans
Default nubie with stupid questions
hi i have been reading on here about the kegger mod and the plenum fix this is a stupid question but are they the same thing? and what is the poormans tb conversion? another question has anyone seen or heard of a shackle reversal for these dodge trucks? my shackles are rusted out and i was thinking about doing a swap. thanks for your time.
Old Mar 26, 2010 | 03:45 PM
Maxx_Magnum's Avatar
Maxx_Magnum
The plenum fix is replacing the gasket and plate on the bottom of the intake manifold, which is also called a 'kegger' because it looks like a beer keg cut in half. The leaky plenum gasket is a design flaw, dodge used a steel plenum plate bolted to the aluminum intake plenum, and differences in expansion between the two mean that the gasket gets torn/pushed out of place.
The kegger mod is something alot of people like to do WHILE doing the plenum fix. It involves cutting the intake runners and divider inside the kegger with a dremel. Helps with throttle response and whatnot.
someone else will chime in about the other questions
Welcome to dodgeforum!
Old Mar 26, 2010 | 03:46 PM
PurplDodge's Avatar
PurplDodge
Welcome To Dodge Forum!
If you have been reading, the Kegger mod is not the same thing as the Plenum fix.
Poormans Tb is just a throttle body that you cut the air horns off to resemble a Fastman Throttle body, but on the cheap.
GeorgiaDodge's Avatar
GeorgiaDodge
the plenum fix and kegger mod are not the same thing. the plenum fix is just fixing the plenum gasket on the bottom of the intake. the kegger mod is cutting down the runners inside the intake and taking out the divider. If you are planning on doing the plenum fix you might as well mod the kegger while its out. do a search on both of theses for a ton of info and DIY links. also Purpldodge will have his long awaited DIY on his plenum fix that everyone is waiting for.
Old Mar 26, 2010 | 03:47 PM
GeorgiaDodge
yall beat me to it. hahaha
Old Mar 26, 2010 | 03:48 PM
Maxx_Magnum
I beat y'all! lol
Old Mar 26, 2010 | 06:50 PM
j_mccans's Avatar
j_mccans
thanks guys for the info any word on the shackle reversal? I know Bds makes a kit how about anyone else? did anyone ever try the stainless headers on ebay for 146.00?
Old Mar 26, 2010 | 06:53 PM
95RAM360's Avatar
95RAM360
just get new shackles....i and others have had the shackles snap in half and throw the leaf spring in the bottom of the bed...not good....so buy new shackles....i paid $47 for both at the dealer
Old Mar 26, 2010 | 06:59 PM
j_mccans's Avatar
j_mccans
wow thats cheap the ones i was looking at were 39 a piece plus shipping
Old Mar 26, 2010 | 07:01 PM
95RAM360's Avatar
95RAM360
Also dont just replace the gasket on the plenum. If you dont get a hughes or aps plenum kit...or the Purpl Plate lol....it will leak again in no time
Its an easy job as well...dont let people tell you its hard.
