What E fan switch do you have "cab switch"
I am finally going to install the switch to the cab for my e fan but i dont know what one to get. what do you have, do you like it, would you change anything?
if your using a controller or use a relay, you can use whatever switch you want. It is up to you whether you want a lighted vs. non lighted etc. how big. I don't have efans, but i have a piece of diamond plate as a switch pannel with two cutout for toggles (which I need to convert to blue... thanks for reminding me). My friend has a section of the lower dash cut out, and has a metal plate rivited to the dash and has his button around the right knee for his override efan switch. But like I said, it is up to your taste.
I like to get low amp switches and let the relays do all the work. A bit more wiring, but it's more efficient and safer. Another reason I like using low amp switches is that generally they are smaller and easier to fit on the dashboard.
