Any Custom/Aftermarket Overhead Consoles?
Old Apr 1, 2010 | 09:22 AM
98formulaLS1's Avatar
98formulaLS1
Default Any Custom/Aftermarket Overhead Consoles?
I have my overhead console. It's the standard one with just the lights and sunglass holder. The lights are the cheapest crap I've ever seen!
I will be upgrading!
Has anyone made any custom ones? Perhaps that hold a CB, or do other useful functions? I understand that I could install one from a different RAM with more electronics in it. If I do that, can I still get the MPG calculator on it to work with my truck?
Thanks in advance fellas
Old Apr 1, 2010 | 09:51 AM
Maxx_Magnum's Avatar
Maxx_Magnum
In order for the console with the computer to work in your truck you'll have to get all sensors and wiring harness from a donor truck.... I think a few here have done it so it's not impossible
I have the same console as you, and I've been thinkin about making some kind of switch panel for it. I never use the console for anything other than the lights, so I kinda thought it would be a good place to put toggle switches for the various things I need them for, rollbar lights, backup lights, etc....
Old Apr 1, 2010 | 11:15 AM
98formulaLS1
can you please be more specific as to what additional sensors you are referring to? I owned an Explorer in which I installed the message console, where all of the data was tapped off of existing sensors, and one wire needed to be installed into the PCM harness to use a pin that wasn't being utilized.
Is this similar to how it's done on these?
Old Apr 1, 2010 | 11:29 AM
Maxx_Magnum
I'm just goin by what I've read here in the past, so I'm not the best to ask, but someone will chime in and help ya out. I know there is a temp sensor either under the cowl or up front near the rad, can't remember much else other than it's a bit of a PITA but definitely doable.
Old Apr 1, 2010 | 11:37 AM
98formulaLS1
well my problem is I only have the 2001 ram FSM, so the wiring to the computers in this version I think are different they my 96. Did any 96's come with a factory alarm system?
Old Apr 1, 2010 | 03:11 PM
dakotas ram's Avatar
dakotas ram
check out lmc.....i know they have some cool ones for 73-79 ford trucks that have speakers and can hold radio/ cb.......not sure if for the rams or not.....might give ya some ideas.....
you could also find someone who does fiberglass and have them make ya a custom one
