What Scan Tool fr my '95 2500?
Old Apr 1, 2010 | 03:12 PM
Ugly1's Avatar
Ugly1
Default What Scan Tool fr my '95 2500?
All the OBD1 tools at the local parts houses have a different connector. Mine actually has two smaller connectors than the single connector the code readers had that I saw. My truck has a 2 row 8 pin connector and a single row 2 pin connector both connectors using what looks to be the standard flat pins.
I am open to any recomendations you kind readers may have on how to get the codes out of my truck. I drove to 3 different parts house this morning hoping to locate what I need to no avail. It really shouldn't be this hard.
Old Apr 1, 2010 | 03:21 PM
Gord.'s Avatar
Gord.
Just turn the key on and off 3 times and count the groups of flashes from the check engine light. The last code you get should be code 55 (5 flashes, short pause then 5 flashes) which means no other codes.
Gord.
Old Apr 1, 2010 | 08:08 PM
Ugly1's Avatar
Ugly1
Cool I think it worked.
I got a 1,2,4,5,3,7,3,7,2,1-55
Since it's been an intermittent CEL while driving in that it's on sometimes then off others I'll assume this is a failing O2 and replace and cross my fingers. I've never replaced it before since I've owned the vehicle yet so I'm due.
Thanks.
