Couple questions on part swaping between 4x4 and 2wd
Old Apr 2, 2010 | 04:46 PM
yakkier's Avatar
yakkier
Default Couple questions on part swaping between 4x4 and 2wd
Just curious if leafsprings and shackles from a 96 2wd will fit mine ?
also would a fuel pump from a 96 be the same as a 94
Old Apr 2, 2010 | 04:52 PM
97tn4x4's Avatar
97tn4x4
Yes the springs and shackles will fit. The only diffference in the 2wd and 4wd is the 3" blocks. As far as the fuel pump when we replaced my dads autozone had the same part number on my 97 as his 94. So it should work.
Old Apr 2, 2010 | 05:01 PM
yakkier's Avatar
yakkier
thanks thats all i needed to know
Old Apr 2, 2010 | 05:21 PM
97tn4x4's Avatar
97tn4x4
No problem hope everything works out for you.
