Old Aug 5, 2015, 12:45 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: 4WD
Print Wikipost
4wd not engaging
Old Apr 6, 2010 | 09:57 PM
dhvaughan's Avatar
dhvaughan
someone posted a site a few days ago for $160. it might have been purpldoge
Old Apr 6, 2010 | 10:01 PM
dhvaughan's Avatar
dhvaughan
by the way - how do you like your Maxxis tires? I was thinking about getting some.
Old Apr 7, 2010 | 08:44 PM
willstruck's Avatar
willstruck
They're awesome. I'd definitely buy them again.
Old Apr 8, 2010 | 08:06 PM
willstruck's Avatar
willstruck
Something occurred to me today. What would happen if the vacuum tubes got switched? I'm pretty sure it's not the problem, since my 4x4 went out when I was off roading, but I had a place drop my tranny. This happened after my 4wd went out, but before I started troubleshooting the problem. If I get in the mood, I'll try swapping the lines and see what happens.
Old Apr 8, 2010 | 08:25 PM
dhvaughan's Avatar
dhvaughan
if you switch the lines, then the cad locks when in 2wd and unlocks in 4wd.
the front driveshaft turns or doesn't turn based on the t-case shift, and has nothing to do with the vaccum lines.
Old Apr 8, 2010 | 09:20 PM
willstruck's Avatar
willstruck
I switched the lines, nothing changed.
I know. The driveshaft locks into the t-case when engaged in 4, so i know it's not the problem. Either the axle or CAD system is the problem. Maybe this weekend I'll have time to see if I can move the collar by hand.
Old Apr 17, 2010 | 02:47 PM
willstruck's Avatar
willstruck
I still haven't tried to move the collar by hand, but I think I might have actually bent the axle. How would I tell?
In the morning, when I get on the freeway I hear a noise that sounds like offroad tires whining. It starts quiet, gets louder, then subsides. It does it between 3 and 10 times, then stops. I don't hear it again until the next morning, when I pull onto the freeway.
Old Apr 18, 2010 | 08:29 AM
dhvaughan's Avatar
dhvaughan
since you've verified your t-case is switching vac properly, and turning the front drive shaft properly. and you've verified the vac lines are good. and you've verified that the shift fork moves back and forth when the CAD is removed from the truck...
then the next step in how things work is the engagement of the collar.
see here.
https://dodgeforum.com/forum/2nd-gen...ml#post2094199
Old Apr 18, 2010 | 07:16 PM
willstruck's Avatar
willstruck
see here.
Thanks. I'll have to dig into it next weekend.
Any ideas about the noise I'm getting? Is it probably a bearing?
