Symptoms of bad axle joints?
Old Apr 5, 2010 | 03:09 PM
CSXfan's Avatar
CSXfan
Default Symptoms of bad axle joints?
Hi all,
I had the dealer replace my passenger side axle joint today on my '99 4x4 1500. They also replaced the axle seal and a couple of other little things while they were in there. They charged be $202 and some change, not too bad.
The only reason I found the bad joint was because I had the windows down and I kept hearing a clicking noise at speeds below 45mph. I pulled the wheel off and found that the joint had about 1/2" of play in it.
What other symptons did I miss? If I hadn't had the windows down I wouln't have noticed it. Would there be some vibration at higher speeds? (70mph +) That's the only thing I have been noticing for the past couple months, but I just attributed that to crappy tires. I just want to know what to look for the next time around so it doesn't get that bad again.
Old Apr 5, 2010 | 05:15 PM
Aubrey's Avatar
Aubrey
It's usually clicking and popping. Sometimes it is different whether or not it is in 4wd or not. Sometimes a high screeching sound like the bearings are all dry and it's metal on metal.
Old Apr 5, 2010 | 05:16 PM
dhvaughan's Avatar
dhvaughan
a bad u-joint is just a loose and/or dry one that has play in it.
depending on how loose it gets - it can make the tell-tale clicking sound and/or make a vibration in the axle, and/or start popping when turning. you often don't notice it till it gets pretty bad.
Old Apr 5, 2010 | 06:08 PM
pwalters's Avatar
pwalters
What steps need to be done to change the u joints do you have to pull it all apart to replace them or are there some tricks?
