Who knows why my truck wouldn't start this morning?
Old Apr 9, 2010 | 10:58 AM
Whaack's Avatar
Whaack
Ok, some other quick information. About a week ago I was driving home and out of nowhere the truck pegged the battery to 18V. My check guages light dinged and I pulled over. I stopped the truck and checked a few things out and then restarted. It hasn't been a problem since. This was a couple days after I replaced the battery.
Would this in combination with the sluggish start and now the no start indicate something else? I will try the suggestion that 95Ram made and also check the ground wire.
Old Apr 9, 2010 | 11:35 AM
redheadhunter21's Avatar
redheadhunter21
Yeah check your grounds and hook your battery up to a charger if you have one, if nothing seems out of place take the battery, alternator, and starter and get them checked
Old Apr 9, 2010 | 03:14 PM
Whaack's Avatar
Whaack
Ok, so got home and started messing around. The battery is perfectly good, not a problem in the world with it. There seems to be something wrong with the negative battery terminal/cables. I jiggled them around and tightened them down and now the beast fires right up. Hmmmm.
Old Apr 9, 2010 | 04:02 PM
xxxcowxboyxxx's Avatar
xxxcowxboyxxx
see.... now isnt that better than replacing the starter, alternator, and battery just bc you didnt know what was wrong. just buy yourself a new negative cable and be done with it. or if yours is still in good shape, put new ends on it,
Old Apr 9, 2010 | 09:18 PM
Whaack's Avatar
Whaack
Yep, that is what I am doing tomorrow! Gonna put new ends on the negative cable and see if that fixes her up!
Thanks for the advice!
