track Bar Question
Old Apr 10, 2010 | 01:19 PM
Jackstand123's Avatar
Jackstand123
Default track Bar Question
I just put on the new bar and have a question about the carter pin if you tighten nut up all the way it does not look right as the pin does not lock anywhere is the nut suppose to be real tighten or what also now my steering wheel is off ....is that because of the new track bar ? thanks for your help! Ron Oh ya 97 4x4 5.9
Old Apr 10, 2010 | 05:03 PM
Jackstand123
anyone?
Old Apr 10, 2010 | 07:36 PM
Jackstand123
Default Is this right?
I've been searching all over is this right? Slide the track bar into the bracket at the axle housing and insert the 18mm bolt through the hole. Place the tab nut on the backside and tighten down the bolt with the 18mm socket. Tighten down the bolt on the top of the track bar, as well. Tighten the bolts as tight as possible, and then loosen them by 1/4 turn to allow the bushings to move freely..........................................on ly thing is the pin does not lock in groove...
Old Apr 10, 2010 | 07:37 PM
rczanstke's Avatar
rczanstke
After installing the new track bar, you will need an alignment. This is why your truck's steering is off.
