Axel wont come out
Old Apr 10, 2010 | 03:50 PM
diveshark's Avatar
diveshark
Angry Axel wont come out
I have a 94 ram 4x4 i need to put in a u joint drivers side axel,i removed the 1 11/16 nut 3 14mm bolts.that sucker is froze in their.i rented a axel puller and slap hammer and it wont budge used pb blaster HELP
Old Apr 10, 2010 | 04:16 PM
J415's Avatar
J415
I heard somewhere here that mixing half tranny fluid and half acetone is 10 times better penetrating lubricant then anything out there.
Old Apr 10, 2010 | 04:21 PM
mnewbolds's Avatar
mnewbolds
If you aren't too worried about saving that one, try heating up the flange around the hub. Don't heat the hub itself. You would be suprised what a little heat can do!
Old Apr 10, 2010 | 11:01 PM
xxxcowxboyxxx's Avatar
xxxcowxboyxxx
put the 3 13mm bolts back in halfway, and use a socket and air hammer on the bolds to use them to push the wheel bearing out. or you can use a chisel end on an air hammer between the wheel bearing and hub to seperate.
Old Apr 10, 2010 | 11:40 PM
mnewbolds's Avatar
mnewbolds
+1 That would be better than the heat
