urgent, need help ASAP re engine noise
Old May 5, 2005 | 04:21 PM
garpoonga's Avatar
garpoonga
Default urgent, need help ASAP re engine noise
am about to drive 800km to buy a 1996 Dodge Ram 2500. The guy says that the engine sounds typically Dodge, with some "valve clatter" is this a normal sound for these engines ? Obvioiusly if it is a considerable noise there is a problem, but what is considered normal for these engines ?
Thanks
Old May 5, 2005 | 04:23 PM
moparturd's Avatar
moparturd
Default RE: urgent, need help ASAP re engine noise
That's pretty subjective. I've never noticed any significant vavletrain niose from any of the Dodges I've owned. SOmetimes other noises may be heard that people don't recognize.
How many miles are on the truck?
Old May 5, 2005 | 04:35 PM
garpoonga's Avatar
garpoonga
225,000 km
Old May 5, 2005 | 04:37 PM
garpoonga's Avatar
garpoonga
I imagine that some noise is normal, I have no idea what to expect, he just said it is a typically noisey dodge engine. Maybe he just means it doesn't purr like some do ?
Old May 5, 2005 | 04:52 PM
moparturd's Avatar
moparturd
225km is a bunch. I suppose if it has good oil pressure and they can give you a maintenance record for the truck....
Old May 5, 2005 | 11:54 PM
Redneck2345's Avatar
Redneck2345
eh, be carefull when you buy a truck with a "noisey" engine, I bought mine and the dealer told me that the tick I heard was a sticky lifter, but the more I listen to it the more it sounds like its coming from the lower end. Just be wary of valvetrain clatter, normaly to get clatter the truck had to be rodded on pretty hard to get the springs weak or the valves sloppy
Old May 6, 2005 | 10:22 AM
nmason's Avatar
nmason
mine has a sort of chatter to it.... been like that for 30000km now. sounds like sheet metal clanging around but i cant find anything thats loose.
Old May 11, 2005 | 02:32 PM
garpoonga's Avatar
garpoonga
Well I bought the truck, I don't know what noise the guy was talking about other then a very slight ticking that goes away when the clutch is pushed in (disengaged) The truck is in amazing shape, no rust, no leaks, interior is clean. The only issues are the sending unit and the brakes drag a little bit when applied but let go as soon as you give it gas or sit for a minute with the pedal off. Minor problems really since the truck was only 9900 bucks !!!!
Old May 11, 2005 | 05:17 PM
steve05ram360's Avatar
steve05ram360
KEWL! when do we see the pics?
Old May 12, 2005 | 12:24 PM
garpoonga's Avatar
garpoonga
I have taken them, I just have to transfer them to the computer and then figure out how to post them in here.
