No manifold gaskets???
Old Apr 14, 2010 | 05:37 PM
Jr. Mechanic's Avatar
Jr. Mechanic
Get these:
http://www.jegs.com/p/Percys/Percys-...81843/10002/-1
Old Apr 14, 2010 | 05:45 PM
aim4squirrels's Avatar
aim4squirrels
I've used the Felpro, Gibson, Remflex and the Percy's gaskets. All have been good, but I use the Percy's now as they are reusable.
The key is getting a good tight first torque. I recommend the Sears long combo wrench in the appropriate size for the boot head.
If the header flange is 3/8ths or thicker, use a 1" bolt. Hedman makes a bolt that is 1" long with a 3/8's head so you can get the combo wrench on all the bolts, even on shorties.
Use blue loktite and torue them as right as you can. Run the engine up to OP temp, then totally cold, retorque. Check at the end of the week, then month, then every 6 months.
Old Apr 14, 2010 | 11:15 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
And repeat as needed, right?
Old Apr 15, 2010 | 02:35 AM
BlueBeast2's Avatar
BlueBeast2
I use remflex. You can find them on ebay as well. I use the grade 8 locking header bolts. Tighten them once and forget about them
Old Apr 15, 2010 | 10:40 PM
motorbrreath's Avatar
motorbrreath
werid... my stock manifolds had gaskets....
i got stage 8s with mine, because the pacesetter bolts SUCK!!!! and the felpro gaskets.
pacesetters arnt true, and leak...
Old Apr 16, 2010 | 12:03 AM
Silver_Dodge's Avatar
Silver_Dodge
That's why Remflex gaskets are so awesome. You can be off by as much as 1/16", and the remflex gasket will still seal it. They are awesome.
http://www.remflex.com/exclusive_features.htm
Old Apr 16, 2010 | 03:15 PM
gipperkid's Avatar
gipperkid
What is the Remflex P/N for the 360 magnum? I see a few different options on their website.
Old Apr 16, 2010 | 05:18 PM
Silver_Dodge
RF6004 for standard use. The others are for special header applications.
Old Apr 16, 2010 | 10:01 PM
gipperkid's Avatar
gipperkid
Thanks!
Old Apr 17, 2010 | 12:59 AM
pcfixerpro's Avatar
pcfixerpro
Bought my remflex off of amazon with free shipping.
