Passenger Side Power Window Not Working
Hello all....I need a little help / advice. I acquired a 2001 Ram 1500 2wd Club Cab from my father who passed away a few months ago. One of the issues I am having is the passenger window will not work from either the drivers controls or the passenger controls. It seems like there is zero power getting to the window motor or maybe the controls. The driver side works just fine. Is there a fuse that might have blown that just works the passenger side window motor or do you think the motor itself has gone bad?? Since my father is no longer with us, I do not know the history of this issue, or how long it has not been working. I want to say it was working when I got the truck, but it has been sitting for a couple of months.
I would like to get some input from you all before I start tearing in to it and break something or take it to the stealership to have them look at it.
Thanks in advance!!
Thanks in advance!!
Probably the motor, but still check the fuses anyways. There's no harm with that. Also check to make sure the passenger side door lock/window switch is fully connected. The window will not move if it's not connected, no matter which side switch you use.
Now let's see some pictures of that truck!
