97 ram rear end question
Old Apr 18, 2010 | 08:30 PM
bmxican's Avatar
bmxican
Default 97 ram rear end question
ive had my 97 ram 1500 for a couple months now and i just started hearing kind of a clicking noise from the passenger rear. when i was checking to see what it was i was pushing on the rear wheel side to side to see if it would make the noise and it did. it almost seems like a wheel bearing with the truck on the ground. but then i jacked it up and took the wheel off and noticed it looks to be the axle is going in and out of the rear end about 1/8 of an inch or less and when it stops it makes the click. the other side on the rear end doesnt do this. is this normal? i know nothing about rear ends so what is causing this?
Old Apr 18, 2010 | 09:17 PM
yakkier's Avatar
yakkier
thats normal, it's going to have a tiny bit of play in it because of the axle shaft that slides into the axle.
but i doubt its what you're hearing its most likely the bearing
Old Apr 18, 2010 | 09:28 PM
dhvaughan's Avatar
dhvaughan
axle sliding in/out a little is normal.
check for clicking in brakes, drive shaft u-joints, front axle u-joints on 4wd.
Old Apr 18, 2010 | 09:58 PM
95RAM360's Avatar
95RAM360
+1 id say u-joints
Old Apr 19, 2010 | 12:34 AM
bmxican's Avatar
bmxican
hmm it just confused me because only one side of the rear end has play in and out with the axle. i guess ill see if its the u joints now
Old Apr 19, 2010 | 07:16 AM
95RAM360's Avatar
95RAM360
well if its an open diff that may be why. think about it, with open diffs the rear doesnt have both tires locked up, and when you turn , if you have noticed, the drive tire switches....so it needs some play to be able to shift.....its hard to explain
