EBay AIRGAP?
I was looking around on ebay and came across this intake. It says it will fit both LA and magnum heads and has both bolt patterns. It also says it has Nitrous/ Injector bosses that are ready to be drilled.
would this work on my 01 if i got an adpater plate for my TB?
Thanks
http://cgi.ebay.com/ebaymotors/MOPAR...Q5fAccessories
Thanks
If this is for real, you can also save a little money and get the satin version.
http://cgi.ebay.com/ebaymotors/ws/eB...%3D1&viewitem=
That's not a Hughes Air Gap. It's different. More than just the finish.
Look at where the bypass hose would connect. It's at an angle. There's already hardly any space in that area, I doubt it'll fit.
Trending Topics
Thats an intake for a carbed engine. There's a little more to it them just drilling injector bungs. You should pass on that until you have the mods to support such a piece, or the skill to fab it to your needs.
The only reason to buy a cheap intake like that is because you know you have the skills to make it work in a MPI engine. Otherwise it would be cheaper to go with an airgap or M1 intake by the time you pay somebody else to make it work.
