Inside a cat ?
Old Apr 24, 2010 | 10:49 PM
yakkier's Avatar
yakkier
Default Inside a cat ?
Just curious if anyone knows what the inside of our cat's look like, my buddy has a durango and he wants to gut his cat and he just wants to know what it looks like on the inside so he can know where to hit the honey comb to bust it out.
He's not cutting it open to do it so i just thought id ask.
Old Apr 24, 2010 | 10:51 PM
william99dodge's Avatar
william99dodge
if i remeber right the whole inside is honeycombed from side to side but if you cut a large enough hole through it you dont have to get all of it out it would be easier just to cut it open though and braze it back on the top of it
Old Apr 24, 2010 | 10:52 PM
GeorgiaDodge's Avatar
GeorgiaDodge
punch it out with a long pick. its like a very small honeycomb and comes out in chunks and powder, watch the 02 sensor tho
xxxcowxboyxxx's Avatar
xxxcowxboyxxx
jason, iv busted apart many, their hollow.....other then the honeycomb. just punch it out with a pipe or bar or anything and then start the truck and rev a bit to blow everythign out. might have to repeat the process a few times. just watch their aint an o2 sensor screwed into it first, might not wanna plunge a pipe into that....
Old Apr 24, 2010 | 10:54 PM
GeorgiaDodge
start punching on the opposite side of the 02 sensor, that way you wont damage it. should come out fairly easy with some elbow grease
Old Apr 24, 2010 | 10:55 PM
yakkier's Avatar
yakkier
yea he's thinkin he's got a plugged cat cause it's hesitating a bit going up a hill and has a kinda muffled sound coming from the tail pipe.
All he has is a cat with a straight pipe out the back
Old Apr 24, 2010 | 10:58 PM
xxxcowxboyxxx
its gonna throw a CEL after you gut it and it may make it run a bit sloppy
Old Apr 24, 2010 | 10:59 PM
yakkier's Avatar
yakkier
Couldn get any worse than it already is man, he doesnt have the check engine light but it's got a major hickup under acceleration
Old Apr 24, 2010 | 11:01 PM
GeorgiaDodge
bust it out. reset the PCM. mine was running fine after that just had a CEL. dont bother me tho cause it runs fine
Old Apr 24, 2010 | 11:02 PM
xxxcowxboyxxx
well if its toast, it cant hurt to gut it anyways. eventually he can upgrade to a high flow cat if t runs sh*tty
