Fog/Driving lights
Old Apr 25, 2010 | 05:57 AM
Taz-man's Avatar
Taz-man
Question Fog/Driving lights
how can i hook up (wiring) extra fog/driving lights to come on & off with key & i will also have a inline switch to turn off manually if not wanted,I can't seam to get access to back of cigarette lighter or i would splice into that thought about putting a aux plug on the end of the hot wire to plug into cig lighter cause i don't use it but plug may get to hot ? i have heard of a tap a fuse ?. Please help !
Old Apr 25, 2010 | 10:42 AM
Sheriff420's Avatar
Sheriff420
http://shop.advanceautoparts.com/web...A|GRP2020A____
That is how I have my dads fog lights connected. I plugged it into the seat belt fuse since his 98 doesn't have a spare slot like mine. I have my reverse lights connected to my spare slot so I didn't need a fuse tap.
You could run that to your switch and just turn them on when you want them on.
Or you could connect your factory fog lights (I assume you have factory since you said extra) and the aftermarket lights to a relay like I did. Then all the fog lights will work with the factory switch.
Old Apr 25, 2010 | 11:05 AM
ghost4321's Avatar
ghost4321
You could use a relay and tap into the switched power to the radio to activate it. IIRC it's the red wire with the white stripe.
Old Apr 25, 2010 | 11:08 AM
Sheriff420's Avatar
Sheriff420
The spare and seat belt fuse slots (among others) are switched also (the key has to be on for them to get power).
Old Apr 25, 2010 | 01:56 PM
Taz-man's Avatar
Taz-man
I have a relay on it now always have had,when i had the lights on my 94 chevy pu it was wired to my fuse bx where it was connected to a fuse that was on/off with key + i had an inline switch on the lights where i could turn them off if i didn't want them on but always where hot when the light switch was on ..chevy trk had the normal size fuse my Dodge has the mini fuse i wanted the lights spliced in to the cig lighter but i can't get to the back of it to do so ,right now it's hooked to the battery Don't want it that way i want it on/off with the key...
Ps
i do have the factory fog/driving lights ..the other lights (extras) are yellow fog lights by Pilot bout 14 yrs old
Old Apr 25, 2010 | 04:38 PM
Taz-man's Avatar
Taz-man
Thumbs up
FYI ,,,, i did take a test light & found a spare in fuse bx in the trk that turns on/off w/key now my extra lights work on that .thanks guys for the info
