Engine swap help
I have a 1999 dodge ram 1500 v6 five speed transmission. i am wanting to pull out my v6 and drop in a stock 318 v8. I know i will need the motor, a new wireing harness, and a new ecu but othere than that will i have any problems? will my stock 5-speed trans bolt right up? will i have to modify the v8 wiring harness to make it work with anything in my factory v6 truck? are motor mounts the same? will ecu from automatic 318 work with a 318 and my manual trans? any help would be greatly appreciated.
the trans will bolt up but you will need the flywheel for a v-8 manual trans, that is what the crank positioning sensor reads, the v-6 has 6 holes, the v-8 has 8, also, the 318 flywheel is different than the 360 (360 has weights on it). you can use your wiring harness from the v-6, just add two more injectore plugs. try to find a comp. from a v-8 manual truck, but i have heard you can take one from an auto and have it flashed for a manual, I have a auto comp. in my truck and it is throwing codes for the auto trans junk that isn't there, but it still runs and drives.
I got my harness with the engine, so I had no prob. with my swap, I just did a little research and the magnum engines have sequential fuel injecion so it looks like you will need to find a v-8 harness,you can't add another couple injector, sorry, but there are alot of dodge v-8 engine in the junk yards right now because of the cash for clunkers and haresses are cheap. You will also need a fan shroud from a v-8 truck
If you get someone like that, don't do what I did, and hang up. Ask for the guy's manager.
