Lift kit suggestions
Old Apr 26, 2010 | 10:45 PM
Dodge115630's Avatar
Dodge115630
Default Lift kit suggestions
I have a 2001 Ram 2500 5.9L V8. I want to put a lift kit on my truck but i have no idea how to go about this. I am only 17 and i am on a tight budget. If anybody has any advice to help, that would be great. I am trying to go for at least a 4.5" lift, but no more than 6". I was also wondering if a lift kit made for a 2001 1500 would fit a 2500. Also if a lift kit made for an '01 2500 diesel would work on a 2500 gas.
Old Apr 26, 2010 | 10:49 PM
yakkier's Avatar
yakkier
2500 is naturally 2 inches higher than the 1500, so a lift kit built for a 1500 wouldnt give you as much lift. you might actually lose height depending on what you go with.
And as far as the diesel goes a 2500 is a 2500 weither it be a 5.9gas or a 5.9diesel.
v10 2500 - 3500 coils might be stiffer but i doubt they'er any higher
Old Apr 26, 2010 | 10:53 PM
Dodge115630
do you recommend a big suspension lift? or a combination of a suspension and body lift?
Old Apr 26, 2010 | 10:55 PM
yakkier's Avatar
yakkier
Body lift and bigger tires. Maybe a add a leaf.
Old Apr 27, 2010 | 10:59 PM
xxxcowxboyxxx's Avatar
xxxcowxboyxxx
put 3500 coils in your front from a junkyard or something, and aal or blocks in the rear. you will clear 35's no prob. my 99 ram was lifted like that and is about 3-4" depending on coil wear. total cost will only be 1-200
Old Apr 27, 2010 | 11:01 PM
yakkier's Avatar
yakkier
cowboy where you been dude ?
Old Apr 27, 2010 | 11:02 PM
xxxcowxboyxxx
busy busy busy. im gonna log on AIM
Old Apr 27, 2010 | 11:03 PM
yakkier's Avatar
yakkier
Im on now
